Bretkennedy74 Posted June 22, 2020 Share Posted June 22, 2020 I recently had to reinstall chief on my computer and now it is not the same as it was when I was using it before; When I create a new plan, I don't have a 'default layer set' under the layer set options for 2, but when I draw a wall of any kind, no temporary dimensions show I am using chief 11. I wanted to know what I need to look at to turn this function on. thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted June 23, 2020 Share Posted June 23, 2020 17 hours ago, Bretkennedy74 said: I don't have a 'default layer set' under the layer set options It sounds like you were previously using an old template plan eg from x9 or x10 migrated forward because as far as I know X11 and now X12 do not have that Layerset in the Default Template any longer. And it sounds like you have toggled the Temporary dimension off on the Right hand toolbar > Large T with a diagonal Arrow under it M. 1 Link to comment Share on other sites More sharing options...
