JeremyNeilKelly Posted June 11, 2020 Share Posted June 11, 2020 Hello, This is Holly at Neil Kelly. I just took the 3D walk through webinar and made a walk through for practice. it was for an exterior and I saw that my fencing layer was not showing. How do you control what layers are showing when you make the walk through? Also when doing an exterior walk through is it possible to have the applied backdrop show or will it be blue? Thank you. Link to comment Share on other sites More sharing options...
robdyck Posted June 11, 2020 Share Posted June 11, 2020 On 6/11/2020 at 8:43 PM, JeremyNeilKelly said: Hello, This is Holly at Neil Kelly. I just took the 3D walk through webinar and made a walk through for practice. it was for an exterior and I saw that my fencing layer was not showing. How do you control what layers are showing when you make the walk through? Also when doing an exterior walk through is it possible to have the applied backdrop show or will it be blue? Thank you. Expand The walkthrough camera is controlled by the Full Camera defaults. Set your backdrop and layer set there. Link to comment Share on other sites More sharing options...
