btlt01 Posted June 4, 2020 Share Posted June 4, 2020 I have a preliminary/first draft plan I am working on for a client. I have several issues going on I can not seem to resolve. This is a new one - I have never had this happen in 12 years of doing this. I have given each room the proper definition. The default ceiling height for floor one is set to 9'. When I tried to change the ceiling height of the living room to 15' and the kitchen to 10' it changed every room ceiling height in the plan. The second issue I have is when I looked at the overview of the house with the roof taken off I noticed that the flooring surfaces in the left side of the house appears to all be concrete. When I tried to open the room definition tab I can not open the room dialog boxes in the 3D overview mode for those rooms. I can when I am in the plan view - just not the 3D rendering. I am hoping the issues are related. I have attached the plan. Kelly_Plan_-_Modified.plan Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2020 Share Posted June 4, 2020 15 minutes ago, btlt01 said: I can when I am in the plan view - just not the 3D rendering Click on the baseboard. Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2020 Share Posted June 4, 2020 17 minutes ago, btlt01 said: I noticed that the flooring surfaces in the left side of the house appears to all be concrete. Those rooms have the floor finish layer defined as a 0" thickness. Make it 7/8" like the other rooms...or the default thickness, or whatever you'd like. Link to comment Share on other sites More sharing options...
btlt01 Posted June 4, 2020 Author Share Posted June 4, 2020 I set the floor preferences in my room definitions before I started the plan so it should have been set automatically and I changed the bath and laundry area manually to slate. If I open the room specification boxes and go to materials tab it shows the flooring I selected, just not in the overview. Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2020 Share Posted June 4, 2020 19 minutes ago, btlt01 said: When I tried to change the ceiling height of the living room to 15' That's because you have a room on the 2nd floor over those rooms. Get rid of a wall so there is not a room over the kitchen or living room. Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2020 Share Posted June 4, 2020 2 minutes ago, btlt01 said: I set the floor preferences in my room definitions before I started the plan so it should have been set automatically and I changed the bath and laundry area manually to slate. If I open the room specification boxes and go to materials tab it shows the flooring I selected, just not in the overview. Then click default. Link to comment Share on other sites More sharing options...
btlt01 Posted June 4, 2020 Author Share Posted June 4, 2020 Moving that attic wall fixed the ceiling height issue - I built the roof manually and used the walls to make that happen. I assumed because I labelled it attic it would not be an issue - obviously I made a bad assumption. Thanks for your help - still working on the flooring issue. It won't even let me use the material painter in the overview mode to change it. If I cant resolve it I'll just make a poly solid and force it until I figure it out. Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2020 Share Posted June 4, 2020 38 minutes ago, btlt01 said: Thanks for your help - still working on the flooring issue Open the room dbx, floor finish, check default. Link to comment Share on other sites More sharing options...
btlt01 Posted June 4, 2020 Author Share Posted June 4, 2020 Thanks - that fixed it!! I appreciate your time and help in this!! Link to comment Share on other sites More sharing options...
