KTKArch Posted May 30, 2020 Share Posted May 30, 2020 (x11) When I open an object to fill (closed polyline etc) I have a standard list and the library option that takes me to Chief's library. It currently only shows that I have patterns of my own making in User Library. It also appears that I can no longer open 3rd party .pat files as I could in earlier versions. And finally, I cannot find a basic EARTH pattern in the defaults. So either I somehow purged some of the patterns or there isn't a default EARTH pattern. And how can I import my earlier .pat files? Not sure if this happened after installing x12 or if it is just this one file. Not using x11 but to finish out this project. Link to comment Share on other sites More sharing options...
KTKArch Posted May 30, 2020 Author Share Posted May 30, 2020 OK...too long staring at the screen... In CA's unknown wisdom they changed EARTH to WEAVE. Not nice to fool with an old man's brain like that. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2020 Share Posted May 30, 2020 You can still use the Import Function and point Chief X12 to the X??> Patterns Folder and Import the Patterns there into your User Catalog Folder but most of Chief's Patterns were moved into the Core Library>Fill Patterns Link to comment Share on other sites More sharing options...
