WildcatFury Posted May 29, 2020 Share Posted May 29, 2020 I have created a 2nd floor using the "Make a blank plan for second floor" and when I go to the second floor and try to click an area to create a room nothing happens. When I created the second floor I left the roof alone because, more specifically I am trying to create a bonus room above a garage. I built a couple of walls but still nothing. Is there a discussion about this somewhere else or a training video that may help? Link to comment Share on other sites More sharing options...
joey_martin Posted May 29, 2020 Share Posted May 29, 2020 You need to turn on the attic wall layer and make those connections. The attic walls are marked NO ROOM DEFINITION by default, so create some breaks as needed and change the walls so that you can get the room definition back. Link to comment Share on other sites More sharing options...
WildcatFury Posted May 29, 2020 Author Share Posted May 29, 2020 Thanks Joey. That worked. Link to comment Share on other sites More sharing options...
