jgranado2013 Posted May 19, 2020 Share Posted May 19, 2020 We're putting in a subdivision and are working on getting the road engineered. The engineer we're using is doing it as side work so he doesn't have all of the CAD programs he would normally have. I've given him a plat with all of the elevation points that the surveyor gave us, but now he's asking for a cross section of the road with stations and elevations. Can Chief do that? I can get a cross section but I couldn't figure out how to get the points and elevations Thanks! Link to comment Share on other sites More sharing options...
robdyck Posted May 19, 2020 Share Posted May 19, 2020 Chief can do it if you can...it's a very simple CAD detail. I'd suggest, however, that the civil engineer should be giving you the cross section of the road, but then again, I don't know your job description, or skill set. Perhaps the town or county or municipality or whatever the governing body is wherever you're doing this project has sample drawings showing the required specs. Link to comment Share on other sites More sharing options...
