dshall Posted May 6, 2020 Share Posted May 6, 2020 Please remind me how to show true sea level elevation. I seem to have forgotten where this is controlled. thanks Link to comment Share on other sites More sharing options...
DavidJames Posted May 6, 2020 Share Posted May 6, 2020 Edit > Default Settings > Dimension > Auto Story Pole Dimensions > Locate Elevations Change value at the top. Link to comment Share on other sites More sharing options...
dshall Posted May 6, 2020 Author Share Posted May 6, 2020 20 minutes ago, DavidJames said: Edit > Default Settings > Dimension > Auto Story Pole Dimensions > Locate Elevations Change value at the top. Thanks David, but you put in a positive number, shouldn't it be negative? Now for the 2 million dollar questionS ...... 1. see pic, Grade Level @ 5' was not auto, I had to do that myself and I had to add the words "GRADE LEVEL". Can this be done auto? 2. See pic. I don't want the "GRADE LEVEL 0" to not even show up (imagine if it was 60' lower). can I do the dimensions be auto and it NOT show the "GRADE LEVEL 0" Link to comment Share on other sites More sharing options...
DavidJames Posted May 6, 2020 Share Posted May 6, 2020 1 hour ago, dshall said: Thanks David, but you put in a positive number, shouldn't it be negative? Now for the 2 million dollar questionS ...... 1. see pic, Grade Level @ 5' was not auto, I had to do that myself and I had to add the words "GRADE LEVEL". Can this be done auto? 2. See pic. I don't want the "GRADE LEVEL 0" to not even show up (imagine if it was 60' lower). can I do the dimensions be auto and it NOT show the "GRADE LEVEL 0" You're correct - it should definitely be a negative number. I just randomly put a numerical value in there 1. I don't believe this can be done automatically - although I could be wrong! 2. In the defaults, you can highlight "grade level" and then select the remove button. See below. All was auto except for the average grade marker which I put in manually. Link to comment Share on other sites More sharing options...
