mariodajti Posted April 28, 2020 Share Posted April 28, 2020 Does anybody know how to manually add a newel/post to a porch railing without having to turn the newels button on after you click on the rail. The problem I am facing is that when I am trying to manually add a newel/post to the rail, you can see the baluster stick out on the post. I used the point-to-point tool for the post. I am using a 3D Symbol but even if I use something from the cheif architect library and manually add it, you can still see the baluster sticking out of the post. Link to comment Share on other sites More sharing options...
mariodajti Posted April 29, 2020 Author Share Posted April 29, 2020 Home Designer Pro 2021. Link to comment Share on other sites More sharing options...
rgardner Posted April 29, 2020 Share Posted April 29, 2020 2 hours ago, mariodajti said: Home Designer Pro 2021. Although there are some similarities between the two versions with this particular part of the software they are done differently. It is highly recommended to look for your answer in the home talk forum so you are not spending your time with answers that don’t work for home designer pro. Link to comment Share on other sites More sharing options...
Usoopk Posted April 29, 2020 Share Posted April 29, 2020 12 hours ago, solver said: You asked on HomeTalk several days ago. https://hometalk.chiefarchitect.com/topic/6110-rail-postsnewels-on-porch/?do=findComment&comment=31419 What software are you using? Thanks man Link to comment Share on other sites More sharing options...
