Fill gap between ceiling plane and cathedral ceiling
jgauntz
I have a cathedral ceiling then I also have a ceiling that is lower than the cathedral ceiling.  I used ceiling planes to create the ceiling under the cathedral, my question - is there an easy way to fill the gap between the ceiling plane ceiling I created and the cathedral ceiling?
You will need to manually draw an "Attic Wall" marked "Roof cuts bottom" precisely where the vault and ceiling planes meet to fill that gap on the "Attic Level" ( I have never had to do this myself before), I guess you could also just create a custom "poly-line solid" object to fill the gap between the vault and ceiling planes. I think the poly-line solid idea is the easiest one to do. Attic walls can be a little twitchy in custom situations.
