MichaelJerome Posted April 8, 2020 Share Posted April 8, 2020 Hi everyone, Can you look at Bedroom #3 on the first floor and check the images that I have provided as well? I can't seem to get the wall drywall to match the sloped ceiling and the roof wants to cut into the second floor wall as if there is not framing there. I also see a triangle shape of framing over the exterior corner window that regenerates is I delete it and click on the build framing symbol. I have looked at all I can imagine to be the issues and now I am not sure what to do to remedy them. The areas I have circled are the areas that I can't create the correct framing without it reverting back after I edit them manually. Please let me know what I am missing. Thanks, Megale Center Plan 2.7.20.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted April 8, 2020 Share Posted April 8, 2020 Have not looked at the plan file yet but are you aware of the "Retain Wall Framing" setting in the Structure tab ? Or even turning off "Auto Rebuild Attic Walls" may help. Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 8, 2020 Author Share Posted April 8, 2020 I have seen that but I felt there was a reason it was reverting due to an error that I had not seen yet. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 8, 2020 Share Posted April 8, 2020 Try turning off "Auto Rebuild Attic Walls" first in General Wall Defaults and see it that helps calm things down. Link to comment Share on other sites More sharing options...
MichaelJerome Posted April 8, 2020 Author Share Posted April 8, 2020 Once again Eric - Your insight is amazing and the video is sooo extremely helpful to follow along and correct the issues. I have not had any classes yet but follow Dan Baumann and watch some of his lessons. I am self taught like most and appreciate your knowledge to help resolve things as they come up and I can't find the exact resource to view like this. Many Thanks, Michael Link to comment Share on other sites More sharing options...
