howardmccall
a serious error occured(exceptions thrown)
A serious error occured (exception thrown) Contact technical support.
While removing some interior walls this message occured.  I can't get rid of it and now I can't even go into other parts of the home and change anything without this stopping me.  If you can help please tell me what to do I have another 6 hours I need to work today.  Hoping for the best
scan0289.pdf
I finally found one a little while ago and yes it would open but if I used that one I will lose about 15 hours of changes.  MIght be the only way around it.  I guess?  but I was having a hard time finding archives and not sure I can find it again.
Did you see you posted this same problem twice?
    28627
    3drenderingltd04
    3drenderingltd04
  • Similar Content
    • By Kbird1
      just wondering if anyone else is get the Error messages in the Latest version ,
      have tried a Reboot and then install straight away but no help this time...
      ( I got the update message this afternoon)
    • By stanlee92218
      I have all of my exterior walls laid out and I have been following along with the video to learn the software, I am new to this! I went to change it to perspective floor overview and I keep getting this error message.
    • By decorators3
      Hi
      I've been away for several months and only now getting back into my CA 11.  But when I open my plan I get this error message.  I've tried updating my library but I have NOTHING no core no bonus no manufacturers.
      Can anyone direct me or do I contact tech support
      Thanks
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief X11, using a Camera View with a Reference Display of the As-Built, I have the As-Built Reference Display file set to render as a Glass House view. The Glass House referenced model displays, but without any of the dark outlines to show the features of the model. I have included an image of a remodel I am working on currently, where the referenced As-Built shows as a faint blue shape. Nothing like the examples Chief gives of a reference display, below.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I have also included an example image from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* in the plan I'm working on. If I were working on a plan and change the rendering technique to Glass House, the outlines are visible. This only happens in Reference Display.
    • By GCCISarah
      Hi all,
      All mirrors from the catalog(s) that I am placing show a bright yellow cast and pixels on the reflective surface of the mirror itself. The mirror IS reflecting the room around it, but the bright yellow color and pixelation never resolves itself. The first photo is the 'Standard' camera view rendering technique, where the yellow is at its brightest. The second attachment is 'Physically Based' rendering technique, where the yellow is faded a bit.
      I had no problems in X10, but this issue has been in all of my plans so far using X11.
      Any thoughts? The mirror material is set as a 'Mirror', with 100% reflection. I've not changed any defaults, preferences, or qualities about the mirror material or camera views that I could think would affect the reflective quality. Help appreciated.
