AlexAncon Posted March 27, 2020 Share Posted March 27, 2020 I have 61 windows in an existing plan and based on the recommendations of the manufacturer of selected windows, I need to change the rough opening sizes. All of the windows are currently expressing the 1/2" per side default and I need to change all to 1/4" per side. Is there a way to do that without opening each window individually? Thanks! Link to comment Share on other sites More sharing options...
joey_martin Posted March 27, 2020 Share Posted March 27, 2020 I would start here... so that you can do windows that are the same size all at once. If you have a few different sizes, you may have to choose those all together by size. For example..the window I show as selected I can choose to find all that match the width and height, and I usually add layer as well, and I can change all those ROs at the same time. Link to comment Share on other sites More sharing options...
AlexAncon Posted March 27, 2020 Author Share Posted March 27, 2020 41 minutes ago, solver said: Rough opening is a default setting that windows will respond to if they are set to use default. Change the default and windows should all change. You can also group select windows like other objects. Click the window tool, then holding shift, marquee select the windows. Thanks very much. That did the trick. Saved me a lot of time. Link to comment Share on other sites More sharing options...
AlexAncon Posted March 27, 2020 Author Share Posted March 27, 2020 39 minutes ago, joey_martin said: I would start here... so that you can do windows that are the same size all at once. If you have a few different sizes, you may have to choose those all together by size. For example..the window I show as selected I can choose to find all that match the width and height, and I usually add layer as well, and I can change all those ROs at the same time. Thank you for your reply Joey. Appreciate it. Link to comment Share on other sites More sharing options...
