Spiral Stairs
tailoredhome
Chief can make spiral staircases easily, just adjust a curved stair. if you need more than 360 deg. you will have to "stitch" two or more stair sections together. For a normal 2.50M high ceiling 180 deg of turn will be enough.
Chief stairs have a good deal of adjustable parameters, and will adjust tread height to reach the upper floor.
If Chief cannot produce what you want, you can try some modelling, make a step then use the multiple copy tools to complete the stair.
you could use Chief to produce a hand rail, and combine this with other modelling techniques.
http://www.chieftalk.com/showthread.php?53239-Spiral-any-Spiral&highlight=spiral
