ChristinoDesign Posted March 15, 2020 Share Posted March 15, 2020 I am trying to dimension countertop to countertop aisle space in my kitchen and bath plan view, we typically show these for client presentation. I can't get the point to point dimension tool to snap to the countertop edge, unless I converted it to a custom countertop. Is there a setting I'm missing? Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted March 15, 2020 Share Posted March 15, 2020 On 3/15/2020 at 1:00 PM, ChristinoDesign said: I am trying to dimension countertop to countertop aisle space in my kitchen and bath plan view, we typically show these for client presentation. I can't get the point to point dimension tool to snap to the countertop edge, unless I converted it to a custom countertop. Is there a setting I'm missing? Thanks Expand are you certain that all the counters are now custom? Plan view or elevation? I have no trouble when using custom tops in either; non custom tops are a problem in elevation. Might post a plan for us to look at. NEED TO KNOW what version of the program you are using. FWIW I never ever use point to point dimensions since those are not snapped to the object but to a new point created when you pull the dimension. Hence those will not change if you move the object. Instead use end to end dimensions. Aisle dimensions are a bit easier if you have a dedicated dimension default for it-only snaps to counters, nothing else, but goes on the same layer used for kitchen cabinets so they show when you want them. Link to comment Share on other sites More sharing options...
ChristinoDesign Posted March 15, 2020 Author Share Posted March 15, 2020 The end to end dimension worked - I knew it had to be a simple change! It was in plan view trying to dimension between a custom top and a non-custom top in version 12. Thanks for your help! Link to comment Share on other sites More sharing options...
