Dimensioning Issues
RobUSMC
I used a remote designer to complete a set of as builts for a small kitchen remodel. When I got it back, I can not figure out why I can not get any automatic temporary dimensions to show. When I select one interior wall I usually will get automatic dimensions the another parallel walls so it can be properly moved into place or just to get basic room size.  I also don't wall wall lengths when a wall is selected (interior or exterior). When I select a door, window or other structure object  I do not get dimensions to the surrounding wall such as from a doors edge or casing to the corner of a room, outside corner or another door or window on that same wall..  Attached is a screenshot and the plan.  Any thoughts please.  Thank you very much.
Anderson_Kitchen_FINAL_DESIGN_3-5-2020.plan
I think you may have unintentionally turned off your temporary dimensions. Look for that tool on your tool bar and make sure it is on.  It'd be helpful to send a screenshot of your entire screen so someone can see it's location and status.
