Polyline hatch line weight not scaling
NectarDesign
Another question,
I can't figure out why this polyline hatch on my floor plan isn't scaling property. I have the hatch fill LW set to 0 and edited that polyline layer to have a line weight of 0. But with all my changes and adjustments it still prints dark. I checked my advanced line weight setting in the print dialogue to make sure it not set to "use 1 for all line weights setting." What am I missing? I'm sure it's simple.
I've attached a pdf of my floor plan (in the CA layout file you can see top hatch has a light grey colour which is what I'd like the print to look like) Then a pdf of the printed layout, sent to PDF using the chief send to PDF setting, 600dpi.
Thanks
I should know that... but forgot about that setting in preferences. Hasn't worked since I switched from x10 to 11, just been putting up with it since then.
Thank you for pointing out the simple solution. Very much appreciate the support on this ChiefTalk group.
