TopagnaOverlook Posted February 25, 2020 Share Posted February 25, 2020 I'm trying to rotate a polyline molding vertically. The molding is laying flat and I want to stand it up on edge against a wall to make a frame. I can only get the rotate/transform tool to rotate it horizontally. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 25, 2020 Share Posted February 25, 2020 Draw the Polyline in the Elevation View. The Molding will then be perpendicular to that view. 2 Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted February 25, 2020 Author Share Posted February 25, 2020 Thanks Joe and Eric, Creating the molding polyline in elevation view worked great. Thanks! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 25, 2020 Share Posted February 25, 2020 I don't think you need to go thru the "CAD Detail from View" to accomplish this. You can just create a rectangle in that view and convert it to a Molding Polyline. Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted February 25, 2020 Author Share Posted February 25, 2020 Here's the result: Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted February 25, 2020 Author Share Posted February 25, 2020 Thanks Eric, Would you use that "trace" technique for something irregularly shaped? What tool would you use for the complex tracing? Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted February 25, 2020 Author Share Posted February 25, 2020 Thanks Eric - I'll experiment with CAD Detail from view. Link to comment Share on other sites More sharing options...
