Is it Possible to Hatch a Deck Railing?
wjmdes
17 minutes ago, robdyck said:
My first thought would be in the railing tab, to change your plan display to a hatch pattern for the rails. Or wall definition.
Yep, I need to add the hatch under Deck Railing Specification under Newels/Balusters and then save to the library so I can reuse it.
FWIW Bill, I realize this should never be an issue, but it's a good idea to at least consider solid color fill as opposed to hatched fill. That way you'll never have to revisit the line weight of the fill pattern should you ever decide to change your line weight settings. Just a thought...
