Elliot Posted February 16, 2020 Share Posted February 16, 2020 I upgraded from Pro to Chief X12 and I'm loving it. And learning it. I cannot find any sign of the "Save Active Camera" icon on the icon bar. Per the reference manual for X12 It should be there. Or I should be able to do 3D/Save Active Camera from the menu bar. But there is no such option in the 3D menu either. So to save a camera I found a work around. I turn on the cameras in my plan view in Active Layer Display Options so I can see the camera itself. Then I select the camera, open it, and there is a check box for saved. And I can rename it there. So it is a workaround but am I missing something or will the Icon be added to the toolbar? thanks Elliot Gesang Gesang Remodeling Graham Washington Chief Architect X12 Link to comment Share on other sites More sharing options...
Dermot Posted February 17, 2020 Share Posted February 17, 2020 The Save Active Camera tool has been replaced by the Save Active View tool. There is also a Save Active View As tool. These tools also replace the Save Plan View and Save Plan View As tools. The Edit Active Camera tool has been replaced by the Edit Active View tool. These new tools will appear in the main Tools menu under Active View. They will work for camera views and plan views so that you don't need different tools for different views anymore. They will still bring up different dialog boxes depending on the type of view you are working in. Link to comment Share on other sites More sharing options...
