DavidAllgyer Posted February 7, 2020 Share Posted February 7, 2020 I can't seem to figure out how to get the wall outline to show up in my Wall Elevation views. This worked fine in x10, but hasn't worked in X11. Any thoughts? Link to comment Share on other sites More sharing options...
Signatures Posted February 7, 2020 Share Posted February 7, 2020 Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk 1 Link to comment Share on other sites More sharing options...
DavidAllgyer Posted February 7, 2020 Author Share Posted February 7, 2020 Do you have a suggestion as to which setting this would be? I have been through the layers setting too often to count, turning them off and on without improvement. Link to comment Share on other sites More sharing options...
rgardner Posted February 7, 2020 Share Posted February 7, 2020 1 hour ago, DavidAllgyer said: I can't seem to figure out how to get the wall outline to show up in my Wall Elevation views. This worked fine in x10, but hasn't worked in X11. Any thoughts? Probably best if you upload the plan file. I don’t have this issue. Also can you please update your signature with not just the software but also hardware info. Many times the answer is dependent on what version and is sometimes tied to a hardware issue such as drivers out of date for you GPU as just example. Link to comment Share on other sites More sharing options...
