Working Plan and Layout File between MacBook Pro (IOS) and PC - Any Issues?
RigsbyGroup
I am looking for some experienced advice...I am looking to switch from a PC and buy the new MacBook Pro16.  We also have Designers using PC Desktops.  Question, will I have any trouble backing up projects on the MacBook Pro16 and then passing them on to someone using a PC Desktop computer to use the same backed up files?
I appreciate any advice!
I'm PC and regularly work with clients on Macs without issue. The only issues would be the same if working different machines all on the same OS-libraries and textures. Since all my clients are remote we use backup entire project though I also sometimes also make a library folder with symbols and textures per project for them. Since you indicated that you are already working multiple machines I'd guess you have the all set up.
    32919
    scottdanville
    scottdanville
