ceiling heights
BillsburgChief
I'm trying to change the height of my Great room from 97 1/8" (default) to 121 1/8".   How do you change ceiling height of a single room without changing the height in all the rooms?  All my rooms are defined by walls and have a defined attic space above.
double click on the room in plan view. That will open the Room Specification dialog box. Structure Tab.
3 minutes ago, solver said:
If you have a 2nd floor, that's what will happen.
Try drawing walls on the floor above outlining the great room below. Then raise the ceiling.
That was it Eric, I guess since my attic was designated as a room. Thanks a ton!
