TopagnaOverlook Posted January 16, 2020 Share Posted January 16, 2020 (edited) Hello, I have what appears to be a portion of roof plane protruding through the ceiling. Circled in red in the interior image below. I've attached the exterior view to explain why the roof plane exists in that location. Suggestions for cleaning this up? Can a roof plane be "notched"? House.plan Edited January 16, 2020 by TopagnaOverlook Plan file attached Link to comment Share on other sites More sharing options...
Chopsaw Posted January 16, 2020 Share Posted January 16, 2020 You may want to raise it just that little bit but you can also break the edge of the roof polyline and reshape it or use the join roof planes tool and it may work automatically. 1 Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted January 16, 2020 Author Share Posted January 16, 2020 Per Chopsaw's suggestion: 1. Select the protruding gable roof plane 2. From the roof plane edit toolbar, select "break line" at the two places the gable plane intersects the shed roof plane over the kitchen bumpout. 3. Grab the edit handle of the newly broken gable plane edge and drag it diagonally so that it follows the shed roof plane edge. 4. Select both the gable roof plane and the bumpout shed roof plane. 5. Choose "Build->Roofs->Fix Roofs". The protrusion is gone. Beauty! 2 Link to comment Share on other sites More sharing options...
Chopsaw Posted January 16, 2020 Share Posted January 16, 2020 Sorry we missed your edited post but at least you got the satisfaction of fixing it yourself. Thanks for showing us your solution and result. Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted January 16, 2020 Author Share Posted January 16, 2020 Thank-you Eric for the forum tips as this was my first post. FWIW, I started with automatic, and then added manual edits and planes. Link to comment Share on other sites More sharing options...
