Simple question? - Different room heights , same floor level
PvdPol
Dear all,
This is probably a simple question, but I cannot figure it out what should be the proper way.
I would like to achieve as drawn below, but somehow my floor of the kitchen keeps on being raised so that the ceilings keep even;
In the past this has been al old barn and the ceiling of the living room is put on top of the kitchen wall/ceiling. This explains the hight difference.
Is there an easy trick? (I'm using CA X11)
I've been checking tutorials which explain 'split-level' but this is not exactly what I would like to achieve.<_<
Thank you in advance!
Regards,
Peter
4 minutes ago, solver said:
Draw the ground floor and set the ceiling heights.
Build the 1st floor checking Step Floor and Ceilings
Set the first floor ceilings as required. Change unwanted walls to invisible.
Thank you for your quick reply, this indeed helped me out. Everything looks fine now without buggy/weird walls.
Eric is amazing...thanks, I never knew about the "step floor and ceilings" option.
