teknoell Posted December 12, 2019 Share Posted December 12, 2019 I have a project that uses 4x8x16 grey cmu block on the exterior of the building (built in the 1970's). Chief has 8x8x16 cmu grey block but I cannot figure how to be able to create a 4x8x16 grey cmu block. Is it possible to use the 8x8x16 cmu grey block and copy it and modify its height from 8" to 4" height? Chief has a "Grey Brick" which looks similar to what I am looking for but the brick dimensions are not what I need. I appreciate any suggestions. I am using X11, Windows 10. Tom Link to comment Share on other sites More sharing options...
robdyck Posted December 12, 2019 Share Posted December 12, 2019 You can change those properties in the 'Define Material' dialog box. Just copy the existing material, rename it and adjust. Link to comment Share on other sites More sharing options...
teknoell Posted December 12, 2019 Author Share Posted December 12, 2019 OK, I'll give that a try and Thank you! Link to comment Share on other sites More sharing options...
