DH7777 Posted November 4, 2019 Share Posted November 4, 2019 I am working with a plan that will have a monolithic slab foundation. The garage floor will be all poured at the same time but dropped 3 1/2" below the main slab. How do I do this? Here is what I did. Drew the main floor plan(including the garage) build terrain perimeter, went room by room and in Rm Specification/Structure and checked the monolithic slab foundation box. In the garage, I did the same but the stem wall box is not on and will not let me adjust it. Am I approaching this wrong? I just got started so there is not much going on with this yet. Attach is the file. 2282.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 4, 2019 Share Posted November 4, 2019 A lot of various ways to go about this, but the key thing here is that you need to set your garage floor to have a negative elevation (this is how you tell the floor to drop down). Link to comment Share on other sites More sharing options...
DH7777 Posted November 4, 2019 Author Share Posted November 4, 2019 25 minutes ago, Alaskan_Son said: A lot of various ways to go about this, but the key thing here is that you need to set your garage floor to have a negative elevation (this is how you tell the floor to drop down). Well as I was waiting I did figure something out. I never "built a foundation" I just labeled rooms as Monolithic slab foundation. So I "built the foundation as monolithic slab and bam! There it was already dropping the garage floor 3.5". But not on the plan I sent, I will have a slab covered front porch dropped as well(same as garage) Do I need to start over as solver suggested? I can open Rm Spec for the porch and it shows stem wall at 4", Floor to SWT 0", SWT to ceiling at 109 1/8" What is SWT? Link to comment Share on other sites More sharing options...
