DanatCV Posted November 2, 2019 Share Posted November 2, 2019 I created scissor trusses in several areas of my design. They all show up just fine in the framing view. But in a 3D perspective, the vaulted ceiling still displays as a conventionally framed roof (ceiling pitch is the same as the roof pitch). I'm a relatively new user so I'm probably missing something. HD Pro 2020 Build: 21.3.1.1x64 Intel Core i5-6300 cpu @ 2.40 GHz 2.50 GHz RAM: 8.00 GB Link to comment Share on other sites More sharing options...
parkwest Posted November 2, 2019 Share Posted November 2, 2019 Did you use ceiling planes to define your ceiling pitch? Link to comment Share on other sites More sharing options...
DanatCV Posted November 2, 2019 Author Share Posted November 2, 2019 Thanks for your reply! The ceiling planes matched the roof pitch when I created the trusses. So I assume I must first create ceiling planes that are the proper pitch to match the bottom chords of the intended scissor trusses before creating the scissor trusses. Thanks again! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 2, 2019 Share Posted November 2, 2019 50 minutes ago, DanatCV said: HD Pro 2020 Build: 21.3.1.1x64 Intel Core i5-6300 cpu @ 2.40 GHz 2.50 GHz RAM: 8.00 GB You can put this in your Forum Signature , so you don't need to post it each time ... https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 some answers are version specific and also in that vain the HD Line has their own Forum over here too: https://hometalk.chiefarchitect.com/ Link to comment Share on other sites More sharing options...
