How to change layout dimension size?
J_Ward
When I send a floor plan drawn at a scale to 1/2" = 1' and send it to a layout page with a scale of 1/4" = 1' the size of the dimension line numbers are just too small.
How can I increase the size of the dimension line numbers on the layout view?
Thanks
Ideally your dimensions should be sized appropriately in your plan view.
There is one option that you can use to change all the dimensions in a layout view though.
Open the dbx for the layout box and go to the Plan View panel, Dimensions.
Change the Number Height.
  • 4 years later...
Same question here. The dimensions size is good in my plan but not my layout view.
I can't seem to find the Plan View panel... I tried opening the settings for the plan but don't see it in there. I'm not sure what the dialog box is. Is that the layout box?
Thanks in advance!
