Creating patterns
mealexmail
Hello guys, long time no see.
I am struggling 2nd day already to find a way of getting custom patterns in CA. It is just terrible!
What I've tried already:
- hatchkit tool (dreadfully awkward)
- coding in a txt file renaming it to pat then (not for complex patterns but for dot-line styles)
- making superhatch in autocad and trying to GETPAT it from there (no success since it doesn't accept exporting shapes, hatch only)
- trying to put it to dxf and getting sections from there using txt editor (just dropped it after 3am)
Dear Big Brain, please help! What I need is very simple: to draw shapes and turn them into custom PATs which will be available for import to CA
HatchKit is a fabulous program once you get the hang of it.  You can either draw the patterns in HatchKit and create a new pattern file; or you can draw in Chief, export as DXF, import into HatchKit, and then create a pattern file from that.  I would suggest you give it another go.
  • Like 2
  • 2 weeks later...
