CMU Walls & floor heights?
ACADuser
Here in Florida we do a lot of CMU exterior walls. I suppose the strength & termite resistance is driving that
Anyway when you have 2, 3 & 4 story houses then floor to floor error (3/4")  adds up.
With a block wall 9'-4" common plate height and 16" common web truss the first floor plate height is 9'-4" of course. But adding another 9'-4" the plate height becomes 20'.
And 30'-8" is the 3rd floor.  So to add in the 3/4" plywood subfloor in the model or not?
I suppose the correct method is to make floor to ceiling heights 3/4" less.  (9'-3.75")
How do you address this problem?
I assume the floor trusses are hung off the masonry wall on a ledger, correct? If so, set the exterior walls to hang the floor structure, then set the the floor levels to your 9'-4" increments:
cmu1.thumb.PNG.94c1324eb4c2b53cdc4884393338e098.PNGcmu2.thumb.PNG.73f1868c31de6d72c25cec76c65987e3.PNG
With this method the actual floor system doesn't matter. This is my normal method of working with cmu, tilt-up, panelized, etc.
