winterdd Posted September 6, 2019 Share Posted September 6, 2019 guys, i forgot how to cut a wall elevation that will show only the framing. if i manipulate layers in the section view layer set i will still need the defaulted layers showing windows and sheetrock in other views. hmmmmm Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2019 Share Posted September 6, 2019 Are you possibly thinking of a Wall (Framing) Detail ? Link to comment Share on other sites More sharing options...
winterdd Posted September 6, 2019 Author Share Posted September 6, 2019 28 minutes ago, Chopsaw said: Are you possibly thinking of a Wall (Framing) Detail ? that makes you draw everything manually correct? here is what i was trying to do since i already built the framing. elevations showing this. (perspective framing overview shown in attachment) i need elevations to dimension. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2019 Share Posted September 6, 2019 It shows an elevation view of just the wall framing that has been auto generated and you can also edit it if necessary or dimension and send to layout. If you want complete elevations of all the framing just set your elevation camera to use the 3D framing set. Only problem is that you will run into issues like the roof fascia covering your top wall plates. I usually just use a 3D framing set perspective view as a general overview of framing. 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 6, 2019 Author Share Posted September 6, 2019 gotcha, thanks! Link to comment Share on other sites More sharing options...
