Foundation Questions
Beyond702
I generated a 8" CMU foundation based on the 1st floor. Now I need to add additional support for the roof. I am try to create multiply 16" CMU "piers" on reinforced concrete slab sections. I would also like the floor beam from above to run across the top of the new "piers". All I can find information on is adding solid wall or posts that sit on a full length rail of concrete. I need individual concrete squares with the 16" CMU sitting directly on top. (I attached an example of what it needs to look like)
My second question is... Once I am done with my plan, I want to transfer a cross section of the exterior wall to Layout. Where can I find the images of my wall sections?
I guess I never really asked a direct question. How can I draw them manually? I watched the training video and to create a slab it shows going to the build Tab on the toolbar and then to select  slab... I do not show the slab subcategory in my dropdown.
