BryceEngstrom Posted September 30, 2014 Share Posted September 30, 2014 In the attached plan, I have a mulled window, and a standard window, each attempting to use a custom, wrapped interior lintel. The window on the right is obviously what I am after. What is happening with the mulled unit on the left? Bug? Secret handshake I don't know? Lintel on Mulled Window.zip Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 30, 2014 Share Posted September 30, 2014 Bryce, My guess is that the lower bank of windows has different size casings than the upper. I would suppress all casings & lintels before mulling and then just add a casing and lintel to the final mulled unit. I did exactly that and it works perfectly. Un-Mull, suppress all casings and lintels from each window, mull the 2 bottom and again suppress all casings then mull the top and bottom together and add the casings and lintel. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 30, 2014 Share Posted September 30, 2014 Oops!!! When I added the Lintel it messed up. My suggestion would be to use a Molding Polyline to create the Lintel - maybe even convert that to a 3D Symbol and just place it on the mulled unit. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted October 1, 2014 Author Share Posted October 1, 2014 Thanks for looking into that. I ended up just not mulling the lower units to the upper one and that works fine for now. Just have to have a casing width space between them. I am going to send it in as a bug. Link to comment Share on other sites More sharing options...
