NTFINEFURNITURE Posted July 21, 2019 Share Posted July 21, 2019 Hello, I'm new at this software, Home Designer Pro 2020, and I need someone to guide me to get a room layout in this odd shape. I manage to do the outside wall, for some reason I cannot upload the .plan file so I upload a .dwg file, I cannot change that shape. This is gonna be a two family under the same roof, 3fl and roof as a 4th fl. I have the ideas in my head, I just don't have the knowledge enough in this software. Could someone guide me or give me some ideas on how to proceed from this point onward? I've attached what I did so far, and pictures of what I want to achieve, thank you for your help in advance. fausto house.dwg Link to comment Share on other sites More sharing options...
lbuttery Posted July 21, 2019 Share Posted July 21, 2019 Hi: HD PRO users can get a lot of benefit from following the Chieftalk forum since PRO has many of the manual tools that Chief Premier has just be aware of the limitations of PRO and that not all advice given here will work for you also always specify that you are using PRO as many of the Chief Premier users are not aware of PRO's features and limitations Lew Link to comment Share on other sites More sharing options...
