Missing Floor
mikes616
Because it's in the attic and not on a new floor. It's a tricky thing to do. Check all the walls for room definition, especially the outside gable wall (which I always forget). You may end up needing to add a second floor, checking the box for the roof to ignore the upper floor, and then you will able to assign that bonus room.
