mikes616 Posted July 11, 2019 Share Posted July 11, 2019 I added a new 2nd floor room but it's not recognizing it as a room and has no floor or ceiling. Any thoughts??? The new room is built over an existing first floor room. Chief 11 user. Thanks. Mark Link to comment Share on other sites More sharing options...
mikes616 Posted July 11, 2019 Author Share Posted July 11, 2019 ok, done Link to comment Share on other sites More sharing options...
joey_martin Posted July 12, 2019 Share Posted July 12, 2019 Because it's in the attic and not on a new floor. It's a tricky thing to do. Check all the walls for room definition, especially the outside gable wall (which I always forget). You may end up needing to add a second floor, checking the box for the roof to ignore the upper floor, and then you will able to assign that bonus room. Link to comment Share on other sites More sharing options...
