DeckQuestions Posted June 14, 2019 Share Posted June 14, 2019 How can I have a full post at the wall? If I uncheck the "half post at wall" option, the post vanishes altogether. Thanks. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 15, 2019 Share Posted June 15, 2019 If like me you like to keep the Post off the Wall ( so moisture isn't trapped and it can be repainted over the years) you can also break the railing wall and reverse the short part to stop them joining again and then position the end of the long section, the width of the newel (post) off the house, though it works for 3.5" posts, you just can't much close or you'll lose the short wall. PS. nice tip on the T-Shape Room Divider Eric , I was just using one in the past...... M. Link to comment Share on other sites More sharing options...
JaredHarding Posted August 2, 2023 Share Posted August 2, 2023 This is great - thanks for the fix! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 2, 2023 Share Posted August 2, 2023 17 hours ago, JaredHarding said: This is great - thanks for the fix! Depending on your Version there is now a Setting in the Railing Wall that lets you "offset from Wall" now. Mick. 1 1 Link to comment Share on other sites More sharing options...
