Evolution Posted June 11, 2019 Share Posted June 11, 2019 I assume once I've drawn the porch in using railing set to invisible?, made it a room (name it porch) then (go to second floor make it open to below?) go up to the (non-existent) 3rd floor, make it also open to below, check ceiling and roof over this room that the issues in the screen captures will be corrected? 1. The fascia is notched at the recesses in the walls on front and rear (this not correct) 2. No soffit Orphanos Foundation Renovations.plan Link to comment Share on other sites More sharing options...
javatom Posted June 11, 2019 Share Posted June 11, 2019 Open the roof DBX. Go to "options". Change your boxed eaves from default to 48" and it will fill in the missing area. 1 Link to comment Share on other sites More sharing options...
Evolution Posted June 11, 2019 Author Share Posted June 11, 2019 That fixed it. Thanks! Link to comment Share on other sites More sharing options...
