SLWilhelm Posted June 6, 2019 Share Posted June 6, 2019 I am working on my first detailed site plan and am having an issue deleting out a terrain line. I had finished the as-built for the house and drew the site plan from a jpeg that I imported from the county GIS site. Once the site plan was done I made a copy and rotated the copy into place. In hindsight I shouldn't have worried about the copy but I like to have a backup the first time I do something. The site plan includes terrain perimeter, contours, and the surrounding roads. My issue is... I was able to delete the roads on the first site plan (the one not rotated into place) but when I delete the polyline that was set as my terrain perimeter it deletes some of the items (roads and the drawn contours) that are part of the final site plan. I am not able to set the terrain perimeter of the final site plan until I delete the first site plan. Is there a way to convert the terrain perimeter back to a CAD polyline so that it is no longer "attached" to the other items and then delete? As I said, this is my first trip down this path so I am having a hard time wrapping my head around why the original terrain perimeter is attached to the roads in the final plan. Oh, and i butchered the original plan trying to delete it so deleting the new and rotating the original into place is not an option. I have a feeling this is a simple fix but I am not finding it. Thanks for any help. Link to comment Share on other sites More sharing options...
glennw Posted June 7, 2019 Share Posted June 7, 2019 It's a bit hard to follow exactly what you are doing. You need to be aware that you can only have one terrain Perimeter in a plan. If you copy a Terrain Perimeter, you do not get another Terrain Perimeter, you get a plain polyline. If you delete a Terrain Perimeter, you will also delete the roads, terrain features, etc, that are part of the terrain. You can convert a TP to a plain polyline by selecting it and clicking the Convert To Plain Polyline tool on the Edit toolbar. Link to comment Share on other sites More sharing options...
SLWilhelm Posted June 7, 2019 Author Share Posted June 7, 2019 Got it. Thanks You're right, it was a bit hard to follow. I selected each item individually, roads first, and converted back to a polyline. Once I converted the roads I was able to do the same to the terrain line and then delete it. I had been staring at the screen too long and missed the obvious. What was throwing me off was that if I converted the terrain line to a polyline first then the roads disappeared but converting the roads first had no effect on the terrain line. Either way, I eventually got there. Link to comment Share on other sites More sharing options...
