Rotate just the lot
Sedona
Hi,
I have been struggling with this for sometime.  I need to rotate the lot (including the dashed setback line) 10 degrees counter clockwise.  I can not find the correct grouping to accomplish it, this maybe related to how close the house sits next the the setback.   I start with rotating everything 10 degrees and the try to rotate just the house back to 90. Instead it also moves the setback with the house instead of keeping it 30’ from the property lines.
I have attached the file if anyone would be so kind as to give it a try or steps I should be taking.
Thank you,
Doug
DK_165_B.plan
Go to your plot plan layerset and turn off or lock anything that needs to stay in position and then use CTRL A and transform replicate to rotate everything at once including the north arrow.
That worked for me.  Thank you!!!
