skoz44 Posted May 21, 2019 Share Posted May 21, 2019 Hi, I've just started using X11 (from X7) and am having issues when sending items to layout. When I tell it to "Send to Layout" with "No Scale" selected, I'm then not able to stretch the view larger or smaller with the corners any longer. When I stretch the corner, it simply moves the line like a polyline. Any suggestions Link to comment Share on other sites More sharing options...
Chopsaw Posted May 22, 2019 Share Posted May 22, 2019 Here are a few options to try : Marque select the layout box or CTRL select and use the little control tab at the top. Or hold down the X key and drag a corner. Drag a side and position with point to point tool. Rotate/Resize about current point works like the software did back in X9 if you hold down the X key it will resize proportionally about the anchor point. 1 Link to comment Share on other sites More sharing options...
skoz44 Posted May 22, 2019 Author Share Posted May 22, 2019 The X key worked perfect. Thanks Chopsaw. Link to comment Share on other sites More sharing options...
