Steel Truss
dfn001
I have created a satisfactory representation for steel floor trusses I am using in my plan, or so I thought.  I set the correct depth for the floor trusses and selected the material from the Steel Stud 16" OC framing default. The 3D Camera shows the material as grey like the other steel beams I have in the plan.  However, when I generate a Framing Schedule, the truss "Material" is listed as Steel Stud 16" OC but the entry under the Type Column is listed as Lumber.  How or where can the "Type" identifier be changed?
