kieran989 Posted May 11, 2019 Share Posted May 11, 2019 Hi there, When inserting doors/windows, the temporary dimensions are referencing the centre of the door/window to the adjacent walls/elements. how do I change this to reference from the edge of the door/window rather than the centre? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2019 Share Posted May 11, 2019 Dimension Defaults> Locate Objects> Openings> Select "Sides" 1 Link to comment Share on other sites More sharing options...
MarkMc Posted May 11, 2019 Share Posted May 11, 2019 What Chopsaw notes controls the individual dimension defaults. Added to that - the current active dimension default controls which default the temp dimensions uses. Example here- only thing that was changed was the active dimension default, no change made to the temporary dimensions default. Pretty handy. Link to comment Share on other sites More sharing options...
kieran989 Posted May 12, 2019 Author Share Posted May 12, 2019 excellent thanks guys! Link to comment Share on other sites More sharing options...
