Robboulton Posted May 4, 2019 Share Posted May 4, 2019 I have a roof built and need to copy the parameters to create another roof. Is there a quick way to pick up the settings and create an identical roof over another section of the house? Link to comment Share on other sites More sharing options...
glennw Posted May 4, 2019 Share Posted May 4, 2019 Copy and paste the roof plane itself. Then edit as needed. You can use Point to Point Move and snap to the roof plane's baseline for accurate placement - usually on the outside of the main wall layer. Link to comment Share on other sites More sharing options...
