Renerabbitt Posted April 23, 2019 Share Posted April 23, 2019 As the title says, couldn't get marquee select to work on headers..is this feature missing? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 23, 2019 Share Posted April 23, 2019 I assume you're referring to Marquee Select Similar right? The answer seems to be no. That tool is not available for wall framing while in plan view...only in a Wall Detail. Can't tell you why though. BTW, Match Properties isn't working for those objects either. Something is broken. Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 23, 2019 Author Share Posted April 23, 2019 1 hour ago, Alaskan_Son said: I assume you're referring to Marquee Select Similar right? The answer seems to be no. That tool is not available for wall framing while in plan view...only in a Wall Detail. Can't tell you why though. BTW, Match Properties isn't working for those objects either. Something is broken. Yes thank you , select similar...and yes just discovered the match props part too..slightly annoying, ha Link to comment Share on other sites More sharing options...
