DRyeHD Posted April 16, 2019 Share Posted April 16, 2019 I am new to CA and am learning by working my way up from the foundation. Typical construction in my area is concrete footing and 8" CMU foundation (16" minimum height). I set up my defaults and drew a 2-room plan (living room and garage) with 4" siding walls for practice. I, then, changed the garage walls to brick veneer. The brick did not extend to the footing. After some research and watching a few videos I've tried using pony walls and setting the brick ledge depth in the main wall type. I have attached a screen clip. It looks like the brick is just barely outside the CMU face. Would someone provide a solution for this? Link to comment Share on other sites More sharing options...
DRyeHD Posted April 16, 2019 Author Share Posted April 16, 2019 Sure thing. I'm working on the new foundation wall now. I will complete my signature shortly. Thank you. Link to comment Share on other sites More sharing options...
Evolution Posted April 16, 2019 Share Posted April 16, 2019 44 minutes ago, DRyeHD said: Sure thing. I'm working on the new foundation wall now. I will complete my signature shortly. Thank you. Go to your profile and select it, in the drop down that appears select account settings, then another menu will open (most likely on the lower left of your screen, go down to signature and select-fill it out there, then be sure to select make public. Link to comment Share on other sites More sharing options...
DRyeHD Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks for the quick reply and help on this subject. Now on to the next thing! 1 Link to comment Share on other sites More sharing options...
