Truss re-labeling X11
BlackDiamond
I just downloaded the latest update to X11 and ever since my trusses are acting differently. Normally when you open a truss or move it, the TR-# will re-label to the smallest unused number available or to match another identical trusses TR-#. It's not doing that anymore. In fact, I've had a tough time getting it to graphically change to an end truss once I check the end truss box. It has also allowed two similar trusses (one an end truss and one not) to be labeled with the same TR-#. I've had a tough time getting it to recognized that they are indeed different trusses.
Any idea why or how to fix this?
Thanks
Things can get messy with truss labels but that does not seem correct.  Any chance you have a duplicate truss?  You can look at the detail sheet and make sure the count is correct.
If it is not that maybe post the file for someone to take a look or send it in to tech.
