builtright3 Posted March 24, 2019 Share Posted March 24, 2019 Is it possible to cut and past this text into a text box and have it come out with this same spacing? I always have to adjust it with font and correct spacing and numbering even if I build something in word first and then transfer it. Link to comment Share on other sites More sharing options...
parkwest Posted March 24, 2019 Share Posted March 24, 2019 Have you tried rich text yet? Link to comment Share on other sites More sharing options...
builtright3 Posted March 24, 2019 Author Share Posted March 24, 2019 17 minutes ago, parkwest said: Have you tried rich text yet? Yes, everything just groups together and I have to space everything the way I want it. Link to comment Share on other sites More sharing options...
Chris_Kelly Posted March 24, 2019 Share Posted March 24, 2019 This isn't exactly what you're looking for but if you get it all set up to your liking once, you can hold Ctrl to group select it and make it a CAD block which you can then save to your library. If you need to unblock it and adjust any of the text it may get messed up again though. That's how I'd do it. 1 Link to comment Share on other sites More sharing options...
builtright3 Posted March 24, 2019 Author Share Posted March 24, 2019 12 minutes ago, Chris_Kelly said: This isn't exactly what you're looking for but if you get it all set up to your liking once, you can hold Ctrl to group select it and make it a CAD block which you can then save to your library. If you need to unblock it and adjust any of the text it may get messed up again though. That's how I'd do it. One I put the text into the Rich Text box it is accurately not bad to make it the way I want it. Its still much quicker than retyping everything. Since I started this thread I have learned a lot about Rich Text and regular text and how to use them. The thing I don't understand is why they have two separate boxes. I don't understand why they could have all the options combined in one box? Link to comment Share on other sites More sharing options...
