Gable Cheek Mess
BFogarty
11 minutes ago, solver said:
I think it's a wall alignment problem.
I made an Open Below room and fiddled with the walls and roof.
Double check dimensions.
23 Cedar St v3 (eric).zip
Thanks Eric!
Attached is a copy of the plan before I had any issues.  The goal was to remove the mudroom/closet walls and bump the entire ceiling up to 12', everything was intact prior to removal.  I figured this may give you an idea of everything that was going on, maybe an answer as well.  I'm just too pissed off with it at this point....soo dumb!
23 Cedar St v1 (ca forum).plan
Am wonder why you have a second Floor ?
Also shouldn't that wall be marked  "if Butting Roof, wall is " ...XXXXXX
PS a number of the basement walls aren't aligned but that shouldn't effect the issue I don't think...
nice job on the Terrain though...
Hmmmm this is a weird one ...it has something to do with the old Garage/basement ....it is building auto walls under the wall you drew for the family room wall..... as soon as I pull the wall back at the exterior door and auto wall pops up and the error fixes itself ?????  see pic...selection is me pulling the 1st wall back....and now look at where the door was....
it gets weirder ..... I deleted all the family room walls and the program is autogenerating what looks like concrete foundation walls
image.thumb.png.31db4229a6bb9281836b27de90dbe819.png  but when you look at the 3D image.thumb.png.b824a898d33dfa4169e26d9b117dca82.png
Weird?  Absolutely.  Normally I can figure dumb stuff like this out....but no such luck today.
Essentially this is a remodel where there was a breezeway/garage, we're using the existing footprint to create one room.  Where that front door was, was bumped out 4' or so from where the breezeway door currently is.   Had no issues until we scaled back and needed to remove some stuff
On 3/23/2019 at 7:10 PM, BFogarty said:
I was going to rip it apart, but I got too consumed with trying to find the problem :)
Sometimes it's just best to not over think things
Had more luck this morning.....
I extended the back wall of the garage foundation to the house , and the used the short wall at the left of the new Family Room entrance on level one and extended it right across the house to the back corner and it built properly with the "Lower Wall if split by Butting Roof" set to 5ee.  I did have to change the material to the 23 Cedar Street Siding from the default though.
Personally for that reason I change the Walltype Definition once I know what they are as CA still does weird thing when "painting" exterior walls in Particular..
I guess the Plan isn't quite finished as I see no Door onto the deck...so couldn't help adding one :)
23 Cedar St v3_MHD2.plan
Personally for that reason I change the Walltype Definition once I know what they are as CA still does woeird thing when "painting" exterior walls in Particular..
I guess the Plan isn't quite finished as I see no Door onto the deck...so couldn't help adding on :)
The door looks great!...lol  One actually has to go there, or we'll extend the deck over and center a door on that back wall.
I'm still stuck on the "why" this happened (I should really move on :), nothing productive in it), do you think it stemmed from the as-built and then the stuff I removed, then adding new floor/walls/roof?  Ultimately something I had set on the as-built didn't jive with the new?
Thanks for your help Mick!
It seems like the As-Built Foundation is auto generating Attic Walls for some reason , and since you used Manual Roof planes you never noticed the Issue, I am not sure why the Walls on Level one didnt stop the Attic Walls on the foundation Level from auto Building , not sure if it has something to do with the weird shape of the old Breezeway foundation and you not fixiing it under the new Family room or not? Sorry I can't be more help......
8 minutes ago, Kbird1 said:
It seems like the As-Built Foundation is auto generating Attic Walls for some reason , and since you used Manual Roof planes you never noticed the Issue, I am not sure why the Walls on Level one didnt stop the Attic Walls on the foundation Level from auto Building , not sure if it has something to do with the weird shape of the old Breezeway foundation and you not fixiing it under the new Family room or not? Sorry I can't be Your help......
Your help/time is much appreciated!
