QualicoreHomes Posted March 22, 2019 Share Posted March 22, 2019 Hello Everyone, I don't use the framing tool too often but thought to try it. I set the header depths for 2x10 but it keeps framing 2x6 headers. I'm I missing something? What would also be really nice is if the double header would be together instead of spaced apart with a plate underneath as drawn beside but I'm not sure if that is wishful thinking. Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 22, 2019 Author Share Posted March 22, 2019 Yes I did Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 22, 2019 Author Share Posted March 22, 2019 Sorry was out for a while and thanks for the replies. I have attached a plan. Headers.plan Link to comment Share on other sites More sharing options...
rlackore Posted March 22, 2019 Share Posted March 22, 2019 You need to set the default header depth for window objects in Default Settings>Window>Framing>Header: Use the Calculate from Width checkbox if you want it to use the default settings you set up in Default Settings>Framing>Openings. 1 Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 22, 2019 Author Share Posted March 22, 2019 Thank you much for the explanation! That fixed it Link to comment Share on other sites More sharing options...
